majids1370
درود
فایل asus b365-plus rev.1.0
ممنون میشم این فایل رو کلیر کنید
چون
چیپ تعویض کردم اما مادربرد حالت امن میاد بالا
The system has POSTed in safe mode
This may be due to the previous POST attempt failing because of system instability
or if the power button was held in to force the system off
If the system failed to POST after you made changes to UEFI settings,
you may wish to revert to stable settings to prevent POST failure.
Press F1 to Run SETUP
چون
واپسین ویرایش:
